flatslide problem
Verfasst: 13 Aug 2007 23:47
von AJS
who can help me
after cleaning and synchronizing a little problem developed in my flatslide carburetor.
after opening the throttle full while riding and closing so I'll ride at a constant speed. sometimes it's not possible to give full throttle again. it will stop at half throttle.
after a while cruising, say a few minutes, it's possible again.
what can this be.???
Verfasst: 14 Aug 2007 0:22
von Marcello
You mean that you cannot open full sometimes ... I think this comes from the adjust screws for synchrosizing.The adjust-screws touch the body of the carburetors inside ... perhaps you open the caburetors above and have a look at this ... :wink: :wink:
With a little bit luck is this your Problem ...
LG Marcello :D :wink:
PS: Micron for President Chef :wink: :wink:
Verfasst: 14 Aug 2007 8:32
von winni
Hi,
Don´t know, if you have also the enrichener solenoid for the flats?
(I have the ZX7 with flats). If this is not connected, the accelerator pumps will not inject additional fuel- no acceleration at all.
Please comment.There is also a good forum under
http://www.redmonkey.com/7r/
Vielleicht ist das Magnetventil für die Beschleunigerpumpen nicht angeschlossen und dadurch wird kein zusätzliches Benzin eingespritzt. Soweit ich weiß, haben die Flachschieber das.
winni
Verfasst: 14 Aug 2007 9:04
von PEOPLES
also für mich hört sich das wieder so an, wie wenn der referenzschlauch der airbox zu den vergasern fehlt/nicht richtig drauf ist, wobei ich keine ahnung hab, wie das nun bei den flachschiebern aussieht, ist ja schliesslich nen L oder M model.
hi winni, if you had normal carbs installed, i would suppose, a pressure-referenz-line between airbox and carbs is not installed correctly. I'm just riding the "normal" CVK-carburetors, so i don't really know much about the flatslide-carburetors. :oops:
Verfasst: 14 Aug 2007 12:33
von Marcello
Ich hatte ihn so verstanden ,daß manchmal das Gas klemmt und er dann nicht richtig öffnen kann (was ein rein mechanisches Problem darstellen würde) ... oder er hat ein Gemischproblem ... (???)
Was meint er denn etz genau :?: smile ... :wink: :wink:
Ich glaub ,die Flachis machen die Kraftstoffumschaltung gesteuert durch die CDI (Magnetventil) bei ca. 4000 1/min ... dann wird mehr Sprit benötigt.
Verfasst: 14 Aug 2007 12:49
von AJS
it's obviously a mechanical problem and i think it will be the adjusterscrews.
hopefullly.!!!!
strange enough it's not a constant problem.
i'll check and let you know
thanks for all the advises you have given
Verfasst: 14 Aug 2007 13:28
von PEOPLES
@winni: so, just to be sure, we're talking about the same proplem: the "throttle-cables" are not jammed? the engine sometimes gives not the power you expect with open sliders- >right?
first thing would be a "simple" blockage somewhere, second thing is probably a fuel/air-mixture proplem or anything which has a influence on it.
sorry for the worse english, i just had a D and that's 8years ago :lol:
Verfasst: 14 Aug 2007 18:34
von AJS
I just checked and the problem is when you ride on the freeway after a while when you want to give full throttle you can turn it only half.
strange.
can't find a problem in the cables so I think the adjusterscrews wil be the problem???
something like : the ramair system pushes agains the flatslides and the get in an angle so that the screws touch the covers.
Verfasst: 14 Aug 2007 18:56
von PEOPLES
i'm sure, the ram-air-effect isn't that strong. i first thought you had a fuel-mixture-proplem :oops:
proplem solving without seen or touching the bike in a foreign language is allways a little difficult. maybe you have to check the carbs an the carb-linkage again.
good luck :wink:
Verfasst: 14 Aug 2007 22:10
von AJS
i know it is difficult.
thank you for helping with the thinking.
the problem is mechanical!!!!!!
but what is it ???
now i have to studie for my exams but over 2 weeks we will find out what it is
Verfasst: 16 Aug 2007 8:28
von winni
Hi
May be there is an adjusting screw of the carbs inside loose or turned out a little bit.
Ciao Winni
Verfasst: 16 Aug 2007 11:58
von AJS
that's what i think.
i know they are not loose, but i haven't checked if they are too far out
Verfasst: 19 Aug 2007 13:36
von mad1111
....u need to turn the screws for synchronisation a little bit more in, maybe its just one....but this is definitly your problem and dont wait 2 long because u can damage the very tiny srecws and your flatside chassis....
mad
Verfasst: 19 Aug 2007 16:43
von AJS
thank you for this information
i'll do it as soon as possible
Verfasst: 06 Sep 2007 10:25
von AJS
I've synchronized the carbs again and it runs perfect.
problem solved. one of the adjuster screws was loose.
only problem now is that it idle speed is not as smooth as it was. but it is not bad.
and it runs perfect. more power when opening the throttle.
thanks for the good advise
Verfasst: 06 Sep 2007 10:59
von ZXR Rider
So, everything ist perfect adjusted for the upcoming Winter Season? :wink: :lol:
Nice Avatar :lol: :lol: :lol:
Verfasst: 07 Sep 2007 10:25
von mad1111
check the adjustment of the speedpumps, for smooth idle...and make sure that gas lines are fix and got no curves...
mfg mad
